Just changed the Oil in my diff - put 200ml more in than came out. Fair amount weeping from seals so removed and cleaned breather (100K miles on car).
Needed a special tool to remove breather - old 11/16 spanner with a 30 degree bend just before the head this means you can get it in and turn without hitting the sparewheel hollow. Even then I'm glad I'm a skinny build with hands to match - wouldn't be easy for those with thick fingers to get it back in.
Some evidence of diff oil being sprayed on the underbody (good rust prevention!) - was wondering are there any of the stop leak (seal softener) products for diffs? Have have very little faith they will actually do anything - but if on inspection in a few weeks fresh oil has appeared on the areas I have cleaned I might be tempted to try some.
