Just washed the car and noticed a rust bubble emerging from underneath the top of the rubbing strip, looks like I need to remove the strip to sort out what's going on behind. Rust is within the recess for the strip so I should be able to sort quite easily.
Before I start any tip on removing the strip, there's a screw at the B pillar end - after that what's next - slide it backwards/forwards? Or are there any nasty clips I have to risk breaking?
