202 front brake pad change
Doodle
Echo Beach
R129, Leon Cupra 290, BMW R100
The C250 is due new front pads (and probably discs) very shortly. I've been reading through the Haynes manual just to see if there is anything unusual waiting to catch me out, and came across this.
Haynes advise that the lower guide pin on pre-facelift models is replaced with a new one. Does anyone know why? I've never had to routinely replace pins or bolts before when changing brake pads on any of my previous vehicles, and cannot see why it is required here provided the part is still in serviceable condition.
Can anyone provide any insight into this?
montur
hi
15mm open ended spanner 13mm socket or spanner pin punch they recommend replacing the pin as parts of it is exposed to the elements and rust my form. it really depends on what yours looks like when it comes out. if rusty it will only be surface so a bit of wet and dry will get it off and leave smooth finish
nickmann
Porsche 911
When I replaced my pads and discs I did not replace that pin. The advice of the dealer was - if it isn't corroded then don't bother.
pluggers
Staffordshire
CLK 200 kompressor w209
Very easy job to do about 45 mins to do each side (pads and disk change).Dont forget to buy some anti squeal grease at the same time about 80p packet.You will need 2 packets 1 for each side.
OP
OP
Doodle
Doodle
Echo Beach
Sounds good to me...that's normally the basis I work on. Shouldn't be too much corrosion, this is the car's first proper winter exposure
