Went out to do the fuel filter on my C240 this afternoon, I knew the mounting bracket had a lot of surface rust so was planning to slop waxoyl around; however realised it's quite easy to strip the whole mounting from the car, so got it all off and had a session of wire brushing (cordless drill) and painting. Took a couple of piccies along the way:
Bracketery halfway through the wire brushing:
Bracketery after being sprayed with hamerite (some old dark green I had around) and then a coat of waxoyl:
Filter was swapped while paint was drying and all re-installed. Well worth the extra time - if yours are rustry, next time you change the filter allow some extra time to sort the brackets out as well.
