p1RATE
im looking at a car and it states it has the following problem...
"Kickdown doesn't work, so if you want to take it over about 3,000 revs you have to change gear manually. It drives fine in "D" if you're not in too much of a hurry though, and all the gears engage OK"
What would be the problem here and how would it be fixed? I hare a w210 that i am taking apart so should have a few spare parts that will be compatible. so if im able to fix it out of that i think i may go for it.
