Hi all.
Im looking for some help on this one. Im checking this car for a friend and it has two symptoms but im not yet sure if they are related to the same fault.
The battery/alternator visit workshop light is on as soon as the engine starts. Ive tested both the battery and the alternator under loads and all is ok.
The other symptom is a squeak coming from the fan belt when reving the engine slightly. The noise isnt excessive but is noticeable.
Im wondering if it is possible that the clutch pulley on the alternator could be sticking and causing both these faults?????
Any help would be appreciated. The car has not had a new alternator fitted to my knowledge but the car has now done 103k miles.
Thanks.
David
Thanks.
David
