n/s wheel arch at the back/bottom behind a plastic panel.
as above it will be your trouble - the fact that it does not work is the clue...............
i must have got luckyNo, the wiring tto the siren often corrodes too and mor often than not the plug connector has to be replaced too.
The pins have to be removed with a special tool and then new pins crimped and soldered. Fiddly little job too.
