I need a cheap set of wheel centres for a new set of wheels. There are loads on ebay but has anyone bought some that fit properly? I imagine they are cheap for a reason in some cases!
Genuine ones from MB are around £15 each, why bother with E-bay knock offs ?? I bought 4 about 20 months ago and they still look brand new.
.. I'm all for oem parts but in this case I bought my replacements (perfect fit) View attachment 81179 from I think the same ebay shop, went to our favourite Italian with the money we saved not buying the MB items!
Here you go...Have you got a link to the exact ones you bought please Ed?
Here you go...
4x Mercedes Benz Alloy Wheel Centre Caps 75mm Badges Blue Hub Emblem - Fits All | eBay
I bought 2 sets, the other in black so I can change them depending on my mood!!
Just looked at the receipt for my original MB ones. £9 each + vat.
Here you go...
they are resin coated whereas mine are not and will tarnish with time
You just need a 'plastic' trim tool to pries them out, something flat screwdriver shaped, but not metal for obvious reasons...Cheers
How do you take them off without removing the wheels?
That's exactly what I was going to say.You just need a 'plastic' trim tool to pries them out, something flat screwdriver shaped, but not metal for obvious reasons...
You could do that. If you're going to use a potentially aggressive wheel cleaner then yesHow about if you spray them with some clear lacquer?
