4 pot diesel.
but finally had to replace the original rear brake discs, they only lasted 305k miles.
I keep repeating this but my 2011 E220 is now on 307k miles with just a rear shock rubber mount with a slight knock at 80k miles and a water pump at 230k miles.
Other than that routine servicing. Just went through another MOT with no advisories, but finally had to replace the original rear brake discs, they only lasted 305k miles.
Doesn't burn oil and will still do 50+ mpg on a run. No rattles, no creaks, no groans, just a small area of cracked leather on the front armrest where my bony elbow has been resting for 307k miles.
Most of mine up to 285k miles was motorway driving, hence the light use of brakes.
Yeah well I only just got this car but I do mainly all motorway driving too so hopefully once it’s all sorted I won’t need to do much maintenance for a while! Apart from standard servicing of course!
I’m also glad I got the 5 speed box as apparently it’s more reliable!
