richard1401
Have looked at all the threads on Roof problems this seems specific
Have replaced Switch bow ram limit switch that fits on the drive cylinder
My problem is as follows (see GF77.30-P2002KA)
Soft Top Closed
Turn lever, Push roof up
Press and hold switch (S84)
Windows drop, Roll Bar lowers (If up)
Soft Top bow unlocks
Soft top bow goes up to approx. 90 degrees
Soft top cover releases and pivots upward
Soft top bow moves into compartment
At this stage it all stops!!
I have always had to give the roof a push at this stage but now it doesn't work
If I turn the ignition Off and On And Close the roof it all shuts and locks OK
(ie Roof now closed with no lights flashing)
If I manually drop the roof into the compartment and close the flap manually
And Manually lock it with the tool
Then Turn the Ignition ON and Off
(ie Roof now fully open with No Light Flashing)
The roof all works and Closes Automatically with no Lights flashing
Hopefully its just a microswitch
Any ideas please - I am on Holiday for a week so will keep looking but cant do anything
Soft Top Closed
