- Mar 11, 2013
- Location
- South Bucks
- CLS63 SB, SLK55, CLK350 'Vert, Triumph Sprint (Bike not Dolly...),
It's a 2013 CLS (Dyslexia Lures KO... ), a 350 CDI on 70K miles.
I've had what may be a variation of limp mode, three times so far in 3000 miles; it feels like limp mode, from what I've read, but see what you think.
It happens right from the cold start. Pulling away, the car revs higher than normal before shifting up, and only accelerates on light throttle; no torque worth mentioning. It revs to about 2500-3000 rpm, no higher, and barely accelerates beyond about 2000. I floor the pedal, and it still barely accelerates, and there's no downshift.
The first couple of times, I pulled over after a mile or so, switched off, then switched on again, and normal operation was restored.
This last time, I was on the way to the office in heavy, fast-moving motorway traffic, and as the car would eventually creep up to 80-85 mph, I left it like that and kept going. I wouldn't say I was using any more throttle cruising steadily at that speed than normal. It wouldn't change down at all on the paddles, and when the speed dropped enough for it to select sixth automatically, it wouldn't change up or down on the paddles, and was very reluctant to change gear at all. Downshifts as the speed dropped were quite harsh, too.
I came off the motorway after twenty miles, stopped and switched off, then restarted, but this time, no change. The rev counter flared by about 400-500 rpm once or twice on (automatic) gear changes, and there was still no power.
Seven hours later, next cold start, everything was normal. I've started it about half-a-dozen times since then; normal every time.
It's never thrown up an EML, and the iCarsoft found no fault codes (current, stored or pending) in the transmission ECU or the shift control module. Could that happen with a failing electroplate?
It's not battery-related; the car had a brand-new battery less than 1000 miles ago to cure (which it did) difficulty in getting it out of Park after a cold start. I don't think it's a low fluid problem, as the fault is very intermittent.
Does anybody have any ideas?
