Hi guys!
I have an S211 E280 facelift that i have some problems with.
1: The lock on the automatic trunkdoor have some issues sometimes. When i open the trunk, i hear a weird sound from the lock, almost that is going in lock again, so when i close the door on the button, the door goes all the way down and try to close, but it will not close the door, and the door came up again.
2: When i start the car, i can't turn on the heater in the front seats. If i wait 2-3 minutes i can turn it on, but it always start with one light, then two, and then three lights in the button. I hear it says click in the relay under the passenger seat.
3: Got an fault code (star) on the in-car temperature sensor. The heater in the car doesn't work well. At max temp it work normally, but if the temp is set to 23 degrees and i start the car, the fan goes for full, and blow only (most) cold air when it's in auto.
The fault code says:
Motor N70m1 (in-car temperature sensor fan motor) does not run.
Someone that have some answers to this problems?
