GeorgeR
After 170k miles (over 9 yrs, 80% motorway) our s212 (normal suspension) started to show its age.
The alignment went out of the spec gradually. It is nothing major, the handling is all good but enough to consume the tyres aggressively. It is the well-known issue: the inside one inch of the front tyres is worn down to the fabric, while the rest is 3-4-5 mm.
The camber is out of spec or on the limit on all four corners, also the caster is getting out of spec. So the front rubber bushing is not in great shape for sure.
What is your recommendation: postpone the refurb and use front camber bolts? How much life left in the rear suspension parts if the front front bushings are getting out of their shape?
If it is camber bolts (front only. I think there is no such for the rear)
I see they do an offset of 2.5-3 mm. How much is it in camber and caster degrees and minutes (or decimal degrees)?
Is the rear toe adjustable on the s212? If so do I need a special bolt there as well?
If it is going to be a refurb then
go for the rubber bushing of the front arms first and leave the rest?
or go for the full refurb ? Just the front or the rear as well?
what are the most likely arms, joints, points to change, renew?
All arms and bushings ? (That is a lot...)
Taking the front: two control arms (per side) for sure, then should I think of the main strut top bearing as well?
Taking the rear: all four arms plus that rubber bushings of the spring control arm (Federlenker) plus the rubber bushing for the thrust arm? Anything else?
Thank you in advance,
