borntobemild
- Feb 9, 2025
- Location
- Near Sheffield
- 2008 Sprinter 4x4 ex-minibus now a campervan, 2010 E350 CDI Blueefficiency Sport Estate
Hi all,
Recently bought a 2010 e350 cdi blueefficiency sport estate. Its a fantastic vehicle but it came with a small problem. The rear O/S had had a little bump which just about crazed the paintwork but did not crack the bumper. When selecting reverse the 4 red lights showed the rear parking sensors had a malfunction. I checked with my iCarsoft scanner and it showed number 7 sensor had a open circuit. I ordered a replacement part A2125420018 which happened to be a Bosch sensor which was an exact replacement for the faulty one. Apart form a real problem .removing the bumper because some numpty had glued it back in place instead of changing a broken bracket, I replace the sensor and still have the 4 red lights. The error code has changed to malfunction wrong component installed. Anyone throw any light on this message as the sensor is the correct part number as far as I can see. I understand all the 4 sensors are identical on the rear. Appreciate any help from y'all.
