220cdi lack of power - not boost pipes
tul214
Beverley
w203 220cdi coupe
Car is in limp home mode - no warnings on dash, there is a whoosing from behind the turbo so i've had the undertrays off and the joint below the cat is blowing. It looks like the clamp (A000 993 24 15) is pretty tight and i assume that after looking at images of the clamp the spring part is for installation only.
What would be causing this joint to blow - blocked cat? if so would it be the rear only?
Any help greatly received
Mark
