Hi
Please can you help with the following questions for my 2016 E220d coupe - especially about climate control because the manual may as well be in Chinese!
1. Carplay
One of the reasons that set this particular car out from others is the fact that it has smartphone integration package and apple carplay 14U and 16U on the data card) yet I can't locate it and don't have any additional integration or navigational features. I can only connect my phone up by Bluetooth as per non smartphone integration/Carplay models.
2. ECO
Why, in ECO mode, does the engine start up if you unfasten your seatbelt or exit the car - that doesn't make sense and is dangerous, too?
3. HOLD
How do you turn on/off HOLD function?
4. PARK
Am I meant to park up and exit the car by putting the car in P, pressing the silver button, and applying the parking brake or do I just turn off the engine and remove the key?
5. ASSISTS
I assume that if I have Distronic Plus, Traffic Assist, Lane Assist, Attention Assist they'll be listed as such in the data card? I have Speedtronic and thermatic climate control and neither is listed in the data card maybe I also have these other functions, too?
6. PARKING
I successfully used Park Assist to parallel park but it left me a good 5 or 6 inches from the curb - is this normal?
7. SENSORS
I think I'm supposed to have front and rear parking sensors but I don't think I've any in the rear because I was only a few inches away from a car and and I didn't get any warning sounds - how can I be sure if I do or don't?
8. SEATBELT
The driver's side seat belt retracts extremely slowly and lethargically, can this be fixed and is it expensive?
9. REARVIEW
I cannot adjust the rear-view mirror. It looks different to the pic in the manual - it's wider on the bottom than the top, there's 2 round lights on the underside but no obvious way to work them or move the mirror and I don't want to force it in case it's electronically adjusted.
10. SPARE TYRE
I do t have a spare and there's no room for one as there's a big hump titled AdBlue where there should be a space to store a spare - does this mean I've got run flats and where would I keep a spare if I decide to fit normal tyres?
And the CLIMATE CONTROL questions......
11. The manual appears to suggest that you should always have the AC on in order to ensure that the car stays cold and that the windows don't mist up - is this correct? Doesn't that make the car drink more fuel?
12. The manual also appears to suggest to always have the AUTO button on otherwise climate control is off and windows will mist up - correct?
13. What does AUTO do? The manual mentions how it maintains asset temperature automatically but surely that's what the temperature setting option does?
Thanks in advance - more questions tomorrow about all things infotainment and Command
1. Carplay
2. ECO
3. HOLD
4. PARK
5. ASSISTS
6. PARKING
7. SENSORS
8. SEATBELT
9. REARVIEW
10. SPARE TYRE
