javaid
- May 19, 2008
- Location
- Live-Cheshire Work-Cheshire Finally
- 280 TE (124K) & 300 TE (178K) & 300 TE (200K) & E300 D (250k), E220 1997 (218k)
Hi
I have a W124 E300 Diesel which has just completed 250K miles and still going strong. This is my fourth W124 estate.
I initiall had the standard steel wheel which I replaced with the standard 195/65 alloys. All good so far.
I then bought some 225 x 45 R17 and was told that they would fit.
During the cold spell when the car was parked for two week without being driven two of the tyres went flat.
I thought that this may be a good idea to change all four wheels. When I changed the rear two and tested the car I found that there was a 'rubbing' noise. I also noticed that the brake pedel did not have as much travel with the new wheels as it did with the old.
So, to my question, can I use these wheels on my car?
If I can then what is the noise that I am hearing, from what I could see I could not see where it may be rubbing?
Do I need to use some spacers or different bolts to secure the wheels.
I looked at the PDF of the and it does show that this size of wheels should fit. Am I doing something wrong?
Many thanks in advance for your comments and advise.
sound Two weeks ago due to to having a slow leak
