- Dec 29, 2013
- Location
- Kidderminster Worcestershire UK
- Mercedes W124 260E M103
did you have the ingnition on.
Obviously if the aux pump is leaking it needs fixing but loss of a little coolant won't result in overheating unless the leak is bad enough/ignored for long enough for the header tank to end up empty. If there's coolant in the header tank (even if the level is low) there's enough coolant in the system for things to work properly i.e. the header tank is sited higher than the top of the radiator and there's a small hose that bleeds a little coolant (and any air) from the top of the rad (or thermostat housing) while the bottom of the header tank feeds into the bottom of rad via a larger diameter hoseThe more I think about this, I think the problem is basically water loss from the auxiliary pump, this then let's the engine overheat in traffic is insufficient coolant, don't recall any warning lights though.
Because the rad was knackered and finally gave up? Water expands by a factor of around 1600 when it changes state into steam...What I don't understand, is why rad blew and not the filler cap.
Head gasket was done professionally a few years back. Genuine mercedes gaskets, I bought them.
What I don't understand, is why rad blew and not the filler cap. Car starts and runs seemingly ok now it's cooled down, only ran it enough to park in place from delivery by breakdown truck.
I will look tomorrow at the oil condition.
Ironically, I have 2 spare radiators, both came from the same model car, but have a feeling they are different to the one on my car, look smaller, maybe because this car has air con ?
Poor grammar is the fault of predictive text on mobile phone and failure of me to proof read before posting. Apologies.
