wardpaa
New mercerdes owner with early problem !
The car has starting Issues when the car is stopped for about 30mins to an hour after being at normal operating temperature. Has been OK if I stop for less time, for example if filling up with fuel.
It usually fires and starts for about a second before dying, then further attempts to start are just cranking only with no firing.
When the car does eventually start after approx 2 mins of trying, it usually requires nearly full throttle to help it fire up.
No issues when cold.
Could it be the dreaded crank sensor at the rear of the engine ?
