kashishchadha18
- Apr 23, 2017
- w221
I have a 2006 Mercedes s class that has gone in limp mode rn and is giving hard shift.
The fault code is see on scanning the car is 2716
When I tried to clear the fault with my mechanic it did go out of limp mode for a bit and start working properly but post 2 hrs after turning it on again, the issue of limp mode happened again
Before this I faced a issue with my car in which it had gone in limp mode and I did not realise and thought it might just be the transmission fuel that's low .
So as a result it broke my ism and I have to change the intelligence servo module which I bought from sino-autobase.com
Luckily the piece worked out for me and when I turned on the car at that moment all was good but immediately after next day this issue of limp mode started and this fault code of 2716 is now a fixed fault code which is current and stored in ECM.
Please help me understand what could be the issue and solution
Pic of the fault code and message attached below
Sent from my ONEPLUS A3003 using Tapatalk
