- Nov 22, 2008
- Location
- Leeds, West Yorkshire
- E280CDI SPORTS ESTATE and C200 KOMPRESSOR SE Coupe Auto (1.8 lit petrol)
Today was the day for another "first-time" job in the refurbishment of my recently-acquired C200 Kompressor.
I had obtained the spark plugs from MB Newcastle - Very efficient and helpful service.
The plugs that I removed were Bosch F6MPP332
Checking the Bosch numbering system table, I can't really determine any difference between the two Bosch Part Numbers.
This car has been pretty-shabbily maintained - as mentioned before.
I feared the worst - and was not disappointed [Actually, I was quite disappointed].
I removed the plugs from a warm engine (It was a cold day).
Plug #1 must have been fitted by a gorilla.
It is much too tight ...... Frighteningly-so.
I was afraid that the steel thread on the plug would pick-up and damage the thread in the head.
I gave it an application of Unilease penetrating oil - Then very carefully worked it back and forth until it started to come out.
[Lessons in foul language for the neighbours].
Fortunately the other three plugs were less tight than #1, but were really all too tight.
The good news is that all came out without damage.
I lightly coated the threads of the new plugs with Rocol "Never-seize".
All went back together correctly-torqued.
All the coil packs and the HT tubes were in good condition - Nice and clean with no burning.
I measured the spark gaps on the old plugs.
All were pretty-bad.
The worse was 1.22mm.
They must have been in for years.
The new plugs were the correct gap of 0.8mm
Result !
MB Pt. No: | A004159450326 (Set of 4) | Bosch No on MB plug - F6NPP332 |
Result !
