280CE Magentic Fan Clutch help!
Merc280CE
1978 280CE Manual
Hi there --
I'm trying to remove an M110 magnetic fan clutch from the water pump shaft. Obviously I've removed the center bolt. But it wont slide off, and there's doesn't appear to be a pin or clamp. Any ideas? Use a pulley extractor on it??
Thanks Ed
Hmm doesnt appear to have a thread. It's a smooth shaft, judging by the replacement water pump ...
Thanks for that. It says 'remove magnetic clutch" but without further instruction ... suggesting there is no secret to it!!
There may be a slight taper on the shaft and the clutch assembly may be tightened on the shaft as the securing bolt is tightened. Or the might have been a bit of galvanic corrosion between the clutch and shaft.
