Dizz
- Jun 4, 2017
- CLK320 (w209)
How much oil (if any) does a 3.2 M112 engine use?
Back when I had one, my 3.2 used no/negligible oil between 6-monthly oil changes.
If you look-up the official figures for consumption, it would have to be very bad indeed (obviously smoky) to get anywhere near them...
More and more new cars are now produced with looser tolerances in terms of clearance of pistons, piston rings, block etc (due to emissions and fuel savings), so it is becoming more common for cars to need a little bit if oil between services. May not be noticeable if you do oil twice as often, but say at 15k/1 year interval, it may well need a little bit.
.... used with the correct fleece filter.....
