30% off Service Parts AND Free Oil Filter
Discussion in 'Parts, Maintenance & Servicing' started by EuroCarParts, Apr 4, 2014.
  1. EuroCarParts
    EuroCarParts Authorised Forum Sponsor Authorised Forum Sponsor
    1,454
    Jul 18, 2011
    Wembley, London
    Car:
    European
    Hi All!
    Today we've launched our SPRING SERVICE SPECIAL where we're offering 30% off AND a Free Oil Filter when you buy Any 5ltr Triple QX Engine Oil!
    [​IMG]
    How To Claim Your Free Filter;
    > Enter your reg & Find your Oil Filter
    > Add your selected Oil Filter to your basket (Any Brand)
    > Find the suitable Oil For your car
    > Add the selected Engine Oil to your basket (ANY 5ltr Triple QX)
    > Add any other parts you require
    > Enter Promo Code SPRING30 at the checkout
    This will give 30% off all service parts (Brakes, Filters, Oils & more) and will change the Filter to £0.00
    If you want to buy more than 1 Oil - then simply add the same amount of filters - and these will be made FREE (upto a maximum of 5)
    As a heads up for You Mercedes owners This codes ALL of the oil filter brands (Bosch, Hengst, Mann, Crosland and even our cheaper Guttmann range) and also the following oils!
    MB229.1 Spec:
    Triple QX 10w40 Semi Syn
    TRIPLE QX 10w40 Semi Synthetic Engine Oil - 5ltr
    Triple QX 0w30 Fully Syn
    TRIPLE QX SynPlus Fully Syn 0w40 Engine Oil - 5ltr
    MB229.4 Spec
    Triple QX 5w40 Fully Syn
    TRIPLE QX 5w40 Fully Synthetic Engine Oil 5Ltr
    MB229.51 Spec
    Triple QX 5w30 Low Saps (APPROVED by Mercedes)
    TRIPLE QX 5w30 Fully Synthetic (Low Saps C3) Engine Oil 5Ltr
    Triple QX 5w30
    TRIPLE QX 5w30 Fully Synthetic (For VAG applications) Engine Oil 5Ltr
    Pat
  2. neilrr
    neilrr MB Club Veteran
    5,997
    Jul 20, 2004
    Car:
    Various.
    Filter is free but oil is not discounting.
    Is that how it's meant to be?
  3. OP
    OP
    EuroCarParts
    1,454
    Jul 18, 2011
    Wembley, London
    Car:
    European
    Hi Neil,
    after you enter the code the SUBTOTAL will be unchanged - below that the GRAND TOTAL will reflect the discounted price (and the free filter)
    Pat
  4. neilrr
    5,997
    Jul 20, 2004
    Car:
    Various.
  5. OP
    OP
    EuroCarParts
    1,454
    Jul 18, 2011
    Wembley, London
    Car:
    European
    hi Neil!
    i just got the same problem however i refreshed the page - re-entered the code and it worked!
    i've asked the Devs to look into it
  6. grumpyoldgit
    grumpyoldgit Hardcore MB Enthusiast
    2,604
    May 7, 2012
    Stourbridge
    Car:
    C270CDI Avantgarde SE
  7. OP
    OP
    EuroCarParts
    1,454
    Jul 18, 2011
    Wembley, London
    Car:
    European
    Hi Mike!
    The TRIPLE QX 5W-30 SynPlus C3 Fully Synthetic (521776061)
    Is APPROVED by Mercedes for MB 229.51
    https://bevo.mercedes-benz.com/bevo...isten&language_id=1&blatt=229.51&suchbegriff=
    You can view the approval on the above sheet - This means the oil has gone to Mercedes, been tested and passed with flying colours - It also means that that oil can be used in a vehicle which requires that specification at any point in its lifecycle - including first fill if so desired!#
    It also means that the warranty will no be voided aslong as the specification if required by the vehicle, and its changed in accordance with the manufacturers specification
    We also have 2 other oils which are VAG approved for use in certain VW, Audis, Seat, Skodas & others which have gone through the same manufacturer approval
    But, you didnt think we'd lie about that did you :rolleyes:
    Let me check the 229.4 - might be a typo :)
    Pat :thumb:
  8. grumpyoldgit
    2,604
    May 7, 2012
    Stourbridge
    Car:
    Hi Pat, Above post edited. I omitted the low saps oil in error, sorry.
    However I'm not after low ash oil, I was looking at the TRIPLE QX 5w40 Fully Synthetic Engine Oil 5Ltr which I can't see listed on 229.1 / 229.3 / 229.5 spec sheets.
  9. OP
    OP
    EuroCarParts
    1,454
    Jul 18, 2011
    Wembley, London
    Car:
    European
    Hi Mike,
    Its 229.3 (your right, there is no 229.4 :p ) - I've updated the product listing on the website - however i can't edit the original post :(
    what spec do you require and i'll have a look
    Pat
  10. grumpyoldgit
    2,604
    May 7, 2012
    Stourbridge
    Car:
    Pat
    Still can't see it listed on sheet 229.3
    https://bevo.mercedes-benz.com/bevo...listen&language_id=1&blatt=229.3&suchbegriff=
    I'm looking for oil which meet and state the MB-Approval. See following...
    The following product list should help you to select the correct operating fluid for your vehicle/major assembly from the variety of products in the market.
    We are recommending to use exclusively the products listed in the following overview, because only these products have been tested and approved by Mercedes-Benz.
    We recommend using only products which are distinctly marked with the label indicating the approval of Mercedes-Benz, e.g. “MB-Approval 229.51”. Labels referring e.g. to “MB 229.51” don't have an approval of Mercedes-Benz.
    Which are listed in the current MB BeVo. Only listed products are tested and approved by Mercedes-Benz.
    I'm also confused about oil filters... Is there a difference between these two?
    [​IMG]
  11. OP
    OP
    EuroCarParts
    1,454
    Jul 18, 2011
    Wembley, London
    Car:
    European
    Hi Mike,
    TRIPLE QX 5w30 Fully Synthetic (Low Saps C3) Engine Oil 5Ltr is APPROVED for MB229.51 (NOT MB229.3) - You can seen this on the approved list here: (use CTRL + F to search for 'Triple QX' or 'Euro Car Parts' - its halfway down the list
    If you require MB229.3 we have....
    Approved By MB for use in 229.3
    Castrol Edge 0w30 FST Fully Synthetic Engine Oil (4 Litre)
    Mobil Mobil 1 New Life 0W40 5ltr
    Castrol Magnatec 5W30 - GM Spec 4Ltr
    Castrol Edge 0w40 A3/B4 4Ltr | Euro Car Parts UK?s No.1 Retailer
    Or we have....
    Meets Requirements of 229.3:
    Theres a few others from our range of Shell, Valvoline and Havoline which MEET the requirements, these can be found by entering your reg on our site.
    Hope that helps to explain it?
    PAt
  12. grumpyoldgit
    2,604
    May 7, 2012
    Stourbridge
    Car:
    Hi Pat,
    Many thanks for clarifying this. Tempted as I am by the TRIPLE QX 5w40 Fully Synthetic Engine Oil 5Ltr, I will stick to an oil that actually has the all important (to me) MB Approval.
    Thanks again.
    Mike
    1 person likes this.
  13. OP
    OP
    EuroCarParts
    1,454
    Jul 18, 2011
    Wembley, London
    Car:
    European
    No probs Mike!
    There's plenty of others to choose from :)
  14. neilrr
    5,997
    Jul 20, 2004
    Car:
    Various.
    When does this SPRING30 offer end?
  15. Howard
    Howard MB Club Veteran
    18,624
    Apr 23, 2004
    Toad Hall
    Car:
    CLS 500 / A 150
    Autumn ?
  16. OP
    OP
    EuroCarParts
    1,454
    Jul 18, 2011
    Wembley, London
    Car:
    European
    hi Neil,
    14th of April - just before Easter :)
  17. Upex
    Upex Active Member
    79
    Apr 12, 2012
    Norwich, UK
    Car:
    2001 s320 cdi w220 & 1998 slk 230 komp r170
    S reg, 230 SLK - what oil spec
    Hi all, just went to use this offer and got confused with all the mb specs.
    Had a look at the bevo thing, and couldn't really find anything useful (that I could see anyway).
    Can anyone advise what SPEC oil I need please, as want to get an order in as need to service next week.
    If anyone van offer ideas to which oils would be a good choice for UK, that'd be grand. It all gets a tad confusing, far too many options, too much choice.
    Cheers all,
    Upex
  18. Leabrooks
    Leabrooks Hardcore MB Enthusiast
    233
    Jan 15, 2014
    Car:
    CLK 270 CDI
    For the slightly dim and the **** retentive MB229.51 graded oil superseded all previous MB spec oils and is now the specified oil for MB's.
  19. Leabrooks
    233
    Jan 15, 2014
    Car:
    CLK 270 CDI
    Going to grab some, thanks ECP!
  20. neilrr
    5,997
    Jul 20, 2004
    Car:
    Various.
    All MBs?
Share This Page
