boomtings
Hi all.
The breather setup in my m104 3.0 estate is looking old, pipes are aged and the mio filter is also not looking in good condition.
I've found a thread on a Audi forum about their breather setup and was thinking of using their one way valve and pcv valve to rebuild my system.
https://forums.quattroworld.com/s4s6/msgs/22506.phtml
I've also seen bmw valves which appear to have an oil catch and return to crancase built in.
But from what I understood these systems are sealed and don't allow fresh air in
Here's a picture of my current system. Sorry it's not the best picture.
http://fastrcmodels.co.uk/M3rcs/IMG_20140119_231532.jpg
I know that the small connection on the rear of the mio filter is suppose to connect to the inlet manifold via a one way valve.
My rocker cover is connected to the mio filter which then exits to a T connector which appear to be connected to the crankcase near the water pump before going to my airbox.
Does my interpretation seem correct?
What I'm unsure of is that I thought the rocker cover pipe was primarily for pulling air into the engine to replace air that is pulled from the crank.
All other turbo technical systems I find pictures of appear to only vent a single connection.
If anyone understands my attempt to describe the set up and can offer any advice I'd appreciate it.
