300 SE W126 running too cool!
Discussion in 'Engine' started by LamboV8S, Oct 29, 2011.
  1. LamboV8S
    LamboV8S Member
    42
    Sep 6, 2011
    Ilkley, West Yorks
    Car:
    SE300 w126 & Discovery
    Hi All,
    Not had the car very long and only done a few short trips but noticed the heater is not giving out much heat and temp gauge don't get much above 65 degree! would have thought 90 ? should be nearer norm?
    It had a brand new water pump fitted before I bought it and assume it's got a new thermostat in?
    Could it just need bleeding?
    Cheers
    LamboV8S
  2. a lex
    a lex Member
    49
    Aug 3, 2011
    Car:
    W140 S280
    Or the viscous fan could be knackered?
  3. OP
    OP
    LamboV8S
    LamboV8S Member
    42
    Sep 6, 2011
    Ilkley, West Yorks
    Car:
    Are they expensive?
  4. a lex
    a lex Member
    49
    Aug 3, 2011
    Car:
    W140 S280
    No idea, sorry - if its only a clutch id imagine not.
    My thinking was if the fan was always running (or running too fast) it would hinder the engine heating up.
    Before tackling that I'd replace the thermostat. Cheap and usually extremely easy to do.
  5. grober
    grober MB Master
    27,851
    Jun 22, 2003
    Perth, Scotland
    Car:
    W204 C200CDI Estate
    Thermostat stuck open or removed would be my guess. If the viscous fan was permanently on you would hear it. Has it got the correct 50/50 water antifreeze coolant mixture in it?
    1 person likes this.
  6. jaymanek
    jaymanek Authorised Forum Sponsor Authorised Forum Sponsor
    16,412
    Nov 29, 2002
    Nuneaton Warwickshire
    Car:
    Id say thermostat too...
  7. OP
    OP
    LamboV8S
    LamboV8S Member
    42
    Sep 6, 2011
    Ilkley, West Yorks
    Car:
    I will check the stat & need to check the coolant, is it special stuff?
  8. ianrandom
    ianrandom Active Member
    998
    Feb 19, 2010
    Berks mainly, UK. Devon too a lot of the time.
    Car:
    1986 420SE, 1990 420SEC, 1989 2CV6.
    Only use the correct coolant. Cant remember which colour but the wrong sort causes corrosion.
    +1, thermostat. Cheap and easy, may as well bung a new one in anyway. MB parts only though.
    Unless your viscous fan is stick on constantly. These can cost £400 but dont pay that, about £60 for a good Sachs one at Euro Car Parts. They are meant to disengage as you go up through the revs in gear. If it 'roars' all the way it could be expired. You should hear the fan roar a bit when you first start the car and for a bit until it settles. Then only if the engine is geting hot.
    There is a secondary electric fan too, that only kicks in when it gets hotter, 100ish i think.
    82 degrees is roughly what the thermostat is set to i think, so that'll be your ideal engine temp.
  9. OP
    OP
    LamboV8S
    LamboV8S Member
    42
    Sep 6, 2011
    Ilkley, West Yorks
    Car:
    Thanks for the advice, will act on it.
    Cheers
    Lambo
Share This Page
