Niks
- Mar 8, 2008
I don't have it on my living room dude,lol
That would be moi... mwahahahaha (i wish)
... I did not feel the need to be more specific about why he did have the same displacement as an AMG engine as he had already given the details in his first post ...
... I have a 300CE 24V engine, (with distributor) and a supposed 60K ...
... I fitted the same engine as you have in to my car (a w124 saloon), and with about £850 in parts and me doing the work it now puts out around 270hp...
Hi
Another brilliant and irrelevant post!!!
from your post, we learned that there's some kind of mathematical calculation that provides horse power figures..well done!!
we also learned that your is fitted with a Split second eco which controls 2 extra injectors to allow more fuel to the KE J system..ok!
and very nice RWP figures...well done! but how is this relevant to the bigger throttle body diameter..
Have you tryed fittig a largee bore throttle body?? if so what was your results??
let us know about the throttle body only...I already my daily dose of irrelevant comments for one day.
mazza
RYBCC, do these percentages change wether the car has a manual or automatic gearbox? I ask because I would expect an auto to create more of a load on the engine than a manual?
Also do you know the rwp of a standard c36 on both types of dyno, I would like to put my car on a dyno at some point to confirm exactly how much power it is putting out and it would be handy to have something to compare it against.
Driveability suffers. If the engine is getting enough air for its needs from a smaller throttle opening you get less progression with your throttle inputs. Effectively the engine will be getting enough air at half throttle opening so your throttle would end up like an on-off switch.What happens when the throttle body becomes too large? Anything bad........
Having fitted Individual throttle bodies to my BMW 02, which provide a significant extra volume over the standard single body, I can safely say it makes a good noise.
QUOTE]
This, I can understand, thank you kindly.......
