Could also well be the fuel distributor itself, which at this age is prone to getting clogged with years of accumulated gunk.
This tends to show itself up as the car will over fuel at idle, which results in a very lumpy tick over that clears once you rev it, or it might stutter and then clear.
To check for over fuelling, idle the car then switch off and pull a spark plug....if its wet on the end its been overfuelling on that cylinder. Repeat, ie idle, then pull spark plug 2 etc etc etc.
I've had to replace two fuel distributors on my last couple of 300CE's.....using injector cleaner makes the problem worse as it scours the crud off the inside of your fuel lines and it collects in the fuel distributor!!!!
The lumpy idle could also be worn injectors
