300SL 1992 main beam dip switch problem
jo_blogs
Hello all -
I bought a 300SL 1992 with a non-functioning main beam on the dip stalk (the dipped lights work fine). The bulbs and relay work because the main beam will flash when you use the flasher on the stalk - it's just in the main beam position itself that it has failed.
Questions:
1. Does anyone know how to gain access to the dip switch - i.e. how to remove the trim from the steering column?
2. Is it possible to remove the tabs that lead from the dip switch and swap them over so that the main beam can use the headlight flasher circuit instead?
3. Does anyone know if a workshop manual exists for this car, and if so where we can get one?
Any help greatly appreciated - jo
