balge
Hi
'92 300TD, om603 non-turbo.
Fuel filters replaced a few thousand miles back
Haven't driven the car recently, missus has been using it... she says it's a bit rough and smokes a bit on starting...
Went out yesterday and it would barely start, much cranking got it going eventually but running rough as anything, clouds of smoke. Smoothed out a lot when thoroughly warm, but still making odd noises, bit like 'pinking'and a trace of smoke (white - grey smoke) and seems a bit down on power - sounds like an injector failure?
Missus says she ran it nearly dry, I put 2 Gallons in and the reserve light came on after about 2 miles, so pretty empty! Just wondered if it could be some crud from the tank rather than damage ie is it worth trying a 'purge' with some kind of cleaner, do they work?
Or just a case for replacement?
I know nothing about the fuel system so any tips appreciated!
cheers
cheers
