My ’88 300TE with 90,00 Km was running fine. It got quite cold here and they spread a lot of salt and gravel on the roads so I parked it at the beginning of November. Com mid December we got some nice dry days so I went to fire it up and do some errands. It was harder than usual to start, but it started. It exhibited a hesitation when you touch the gas. After driving for 10 minutes the hesitation became a stall and it became increasingly hard to start each time it stalled. I got it back home, into the garrage but by then, it was next to impossible to start.
I took out the plugs (with about 1000 Km on them) and found them soaked with gas and carboned up. I found that if I cleaned them and it was a fairly warm day (0 degrees C or warmer) you could start the car, but only once. Next day there would be no chance of starting it again unless you take out the plugs and clean them.
Here are the things I did in sequence:
This motor must need an awfully strong spark to run. I remember my friend bringing over his old VW Rabbit (about an ’81) saying that it didn’t start as good as it used to. I measured the voltage on the +side of the coil and due to a bad connection at the back of the fuse box it was only getting 2 Volts!!. The VW still ran fairly well. I can only imagine what the 300TE would run like with that kind of voltage. These hard to start symptoms and hesitation seem to be common on this motor whenever the mixture is not quite right or the spark is not absolutely top notch. I wonder why?
- Checked the spark by using a sparkplug outside of the engine. It looked nice and bright to me.- Measured the battery voltage (over 13V).
- Replaced the OVP relay. A previous owner had pried mine apart and the contacts looked black (the new one made no difference).
- Since the plugs were soaked, and I had put in a bit of gas line antifreeze so I took off the fuel distributor to make sure the fuel control plunger was not stuck – it was fine.
- At this point I towed it over to the local German Car garage (mostly VW/Audi, but the sign outside says, VW, Audi, Porsche, Mercedes, BMW). They put in new plugs and roter and charged me about $200. I went to pick it up, and yes it started but when I touched the gas it died. I told them about it and they made a good try to further diagnose the problem the kept it for a month and did the following:
- Checked the fuel pressure and made sure that both fuel pumps were working.
- Replaced the fuel filter
- Did a smoke test to look for any vacuum leaks.
- Replaced the idle change over valve.
- None of these things helped, it was still exactly as it was when I brought it in, so they told me to come and get the car, I had it towed home.
- Since the plugs were getting wet, I replaced the cold start valve and put in a switch to disable it and a light to tell me when it was on or not. It was getting power exactly as the manual says it should. The car didn’t start with it turned off either.
- My Fuel pressure regulator was all covered in silicon by the previous owner to cover a break in the rubber hose, so I replaced that. No difference.
- I used an oscilloscope to check the coil drive signal coming out of the EZL ignition control unit. It went from about 0V to about +10 so I figured that was working okay.
- Today, I replaced the coil with an after market coil from Hqamburg-Technic and Voila! it started and ran again so I’m hoping that my problem is finally solved.
