311rob
Hi, I'm in the process of trying to install an alarm system, but in a muddle with the wiring. Do I connect the alarm wiring to the loom behind the glove box?...seems to have loads of wires with factory made connectors or blue caps, as if this is the place to make connections.
Secondly, door trigger switch wiring...connect to the same loom?....or like the instructions say, directly at the switch?...and finally, wiring to go to main 12v, immobiliser etc, connect up at the steering column?
I have the necessary wiring diagrams, but nothing is indicating exactly where in the vehicle to make these connections.
Any help will be greatly appreciated.
