320 M104 top end tapping noise
Discussion in 'Engine' started by growlygrowler, Aug 27, 2011.
  1. growlygrowler
    growlygrowler Active Member
    62
    Aug 20, 2009
    Car:
    1990 500SL
    Folks
    A question since I don't really know the M104 320 engine:
    There's a ticking from the top end. It rises and falls in frequency with the engine revs. Present both hot and cold. Follows the engine revs to about 2000rpm at which point it seems to disappear.
    Any ideas? Do these have hydraulic lifters? Is this common?
    It's on a car I looked at for my niece - a very well maintained W140 S320 1993. The head gasket (usual leak), water pump and wiring loom have been replaced at about 100k according to the service history and it's now on 108k.
    cheers
    Dave
  2. WDB124066
    WDB124066 MB Enthusiast
    6,176
    Apr 17, 2009
    Car:
    1996 E320 Sportline Cabriolet x 2
    Most likely due to weak hydraulic lifters, Mitsubishi are the only ones to do an oil treatment that I know works - for a while. This from the Forman of our largest MB Dealership.......!??
    Otherwise, oil and filter change might make a difference, but they can be replaced to quieten them down.
  3. OP
    OP
    growlygrowler
    62
    Aug 20, 2009
    Car:
    1990 500SL
    Hi - thanks, that's what I figured.
Share This Page
