320cdi start times
Discussion in 'Engine' started by amolak, May 18, 2013.
  1. amolak
    amolak Active Member
    277
    Mar 22, 2003
    Car:
    B200Turbo & V350
    Hi, Starting car in the morning, takes about 4 secs to start. All day it starts immediately. If car is not used for a week, takes about 6-7 secs to start.
    Glow plug comes on normally, and I begin to start once it goes out.
    Is this normal?
  2. proser
    proser Active Member
    753
    Nov 29, 2008
    Stafford
    Car:
    W210 E320Cdi Estate
    I would say yes
  3. Bakili
    Bakili Active Member
    292
    Apr 12, 2013
    South Yorkshire
    Car:
    Mercedes E320 CDI W211
    I have similar issue, but starts straight away first time, and after takes longer to crank (say max 4 sec). If I leave car parked for 1hr + will start straight away again.
  4. mersum1es
    mersum1es MB Enthusiast
    1,299
    Aug 9, 2012
    Finland
    Car:
    W219, W220
    I've no experience about V6 diesel, but I would say that's symptom of very early stage 'low fuel pressure at start' issue. May be due to leaking injector or jamming fuel control valve etc. (these engines are free of faulty o-rings is low pressure lines). But unless starts always at first time, I wouldn't worry...
  5. OP
    OP
    amolak
    277
    Mar 22, 2003
    Car:
    B200Turbo & V350
    Thanks, to confirm, don't the CDi engines have o-rings in the fuel lines?
    Would u say the diesel filter is operating okay?
    Some internet threads seem to point towards replacing the glow plug module.
  6. SL300-24
    SL300-24 MB Enthusiast
    1,739
    May 28, 2004
    Essex
    Car:
    2007 CLS 320CDI,1984 500SL, 2007 E320 CDI Sport Estate, 1991 230TE
    Yes thats what it probably is, the glow plug module gone open circuit, just changed one on mine.
    Do you get a lot of white smoke when it starts for the first time in the morning?
  7. OP
    OP
    amolak
    277
    Mar 22, 2003
    Car:
    B200Turbo & V350
    no white smoke, I read somewhere that the cdi engine doesn't use the glow plugs unless temp is below zero
  8. mersum1es
    1,299
    Aug 9, 2012
    Finland
    Car:
    W219, W220
    CDI3 engines have somehow better design and that CDI2 generation o-ring issue is not so valid any more.
    I think glow plugs are used, but it's not so important when temp is higher. V6 diesels are lower compression ratio and are requiring glow plugs more than inline CDIs, it could be worth to check the control module.
    I would not blame the filter if it is changed not more than 2 years ago.
  9. OP
    OP
    amolak
    277
    Mar 22, 2003
    Car:
    B200Turbo & V350
    Thanks, are the 2006 320cdi engines cdi3 or cdi2? can you by visual inspection see if the o rings are ok?
    how can you check the module without buying a replacement?
    thanks
  10. SL300-24
    1,739
    May 28, 2004
    Essex
    Car:
    You can check the module with a code reader......
  11. sspeed
    sspeed MB Enthusiast
    1,019
    Apr 19, 2009
    Near Blackpool..... But not TOO near !!
    Car:
    2006 CLK320 CDi
    My E320 Cdi takes around 4 seconds when its the first start of the day..
    My car has only done 38k miles so I doubt its clapped out just yet.
    Once its been started that day then I would say 2 seconds is the norm.
    1 person likes this.
  12. OP
    OP
    amolak
    277
    Mar 22, 2003
    Car:
    B200Turbo & V350
    Thanks, what if u haven't used it for a week, is it still 4 secs?
  13. Dieselman
    Dieselman Banned
    34,206
    Jul 13, 2003
    Car:
    Peugeot 403 Convertible
    My suspicion is that the injectors are leaking back a bit so fuel pressure has to be built up before the engine can fire.
  14. Dieselman
    Dieselman Banned
    34,206
    Jul 13, 2003
    Car:
    The old clunker is about 1 second after a couple of seconds of glow.
    I think Your longer start time is a result of lower compression ratio.
  15. BAZZER1
    BAZZER1 Active Member
    272
    Jul 18, 2011
    FERNDOWN DORSET
    Car:
    mercedes e320cdi estate
    Mine takes the same time as Steves about 4 secs initially first thing and then pretty well first on the button all day after that.
    This is normal for an E320cdi, don't worry about it.:thumb::thumb:
    BAZZER1
  16. OP
    OP
    amolak
    277
    Mar 22, 2003
    Car:
    B200Turbo & V350
    Thanks Bazzer1, what if u don't use the car for 1 week how long does it take to start then?
  17. OP
    OP
    amolak
    277
    Mar 22, 2003
    Car:
    B200Turbo & V350
    If that was the problem, then surely it would affect starting during the day too?
  18. sspeed
    1,019
    Apr 19, 2009
    Car:
    2006 CLK320 CDi
    To be honest I haven't left it a week yet so I honestly don't know..
    I have left it 2 days max so far and its initially 3 or 4 seconds.
    My C270 Cdi went through a patch of Very bad starting.. I replaced all the O rings in the low pressure fuel pipes and all was spot on after that..
    Its not a mileage thing with O rings.. Its Age that flattens them out..
    They don't leak Diesel as such (Micro weeping that's all) but as the engine cools they allow air to be drawn into the pipes. This means the engine has to re bleed itself of air before it starts.
    That condition only happened first thing in the day..
  19. OP
    OP
    amolak
    277
    Mar 22, 2003
    Car:
    B200Turbo & V350
    thanks, are those the pipes that go into the fuel filter. I read somewhere that the 320 engines don't suffer so much with o ring issues.
  20. SL300-24
    1,739
    May 28, 2004
    Essex
    Car:
    I would read the fault codes before you start ripping things apart, I still think it is the glow plug module.
Share This Page
