Hi All,
Bit of an odd one this. I've recently fitted a brabus D6III to my CLK 320cdi v6 (2006). The unit serial was confirmed by brabus that it is correct for the vehicle and that it has the right programming.
After fitting the unit to the car, you can definitely notice the difference, however in higher gears and at 3-4k rpm under load (usually after a kick down), the car seems to 'die' and i notice a slight bit of vibration. Back off the accelerator, try again without kick down and the car will rev.
* Car has recently had new MAFs (mainly because the air intake y piece was cracked and this is a single unit).
* STAR shows no codes. When the incident happens, the car doesn't go into limp mode. Lower speed 'normal' driving is fine.
* Car had the ATF changed by MB 6 months ago.
Part of me thinks it could be gear slip due to the extra power. I haven't had a chance to remove the chip and try again, just yet.
Any ideas?
Any ideas?
