BiggusDickkus
My 2009 350SL is suffering from a rear suspension anomaly. I have owned the car for 3 years and it has always had a tendency for the rear of the car to step sideways when driving over a bump or a rough road surface. Its worse on the nearside than the off side. The car is low mileage, as in 23,000 miles from new. Recently I had a garage change all 4 dampers for new Bilstein OEM types, and in doing this it has made this problem much worse. On a straight flat road the car behaves well including round corners, but as soon as the road surface is rough or if there is a manhole or pothole the car lurches towards the side of the road where the poor surface is. It does the same on both sides but the near side is much worse than the off side. The car is in excellent condition and I am a little mystified about this problem. I had a similar problem on an E46 M3 about 10 years ago. Three BMW garages could not find it, but a suspension specialist found the problem to be a faulty bush in one of the rear wishbones. Because of this I am suspecting that it could be one of, or a few of, the rear suspension bushes, or even a subframe bush(s). Has anyone else encountered this problem and if so, what was the solution? Forgot to say my car is the sports version with 19" AMG wheels. The tyres (Continental ContiSportContact 6) are relatively new, having only done about 2000 miles. I would welcome any advice...
