KenF
I am losing brake fluid by the pint. I have looked underneath and can't see the leak but the steering box is soaked. No sign of a leak in the wheel well and the top is so pristine that it is even hard to imagine any corrosion so close.
I'm just wondering if the master cylinder seal is leaking and if anyone has seen this problem before. It started leaking quite suddenly so I suspected a broken line - is there another line under there?
This is the400E so there is just no way to see under the master cylinder without pulling it. The problem I have is that if I start to pull things apart (from on top) I am not sure that I will be able to find the leak because there is going to be fluid everywhere!!
Anyone got any pointers? Please!
BTW, does the reservoir just pull off?
