420sl r107 1989
Redeyez
420SL
Hello Everyone
I have a problem with my SL 107 in that no rear break lights are working, I checked the bulbs and they are fine, also tested with multi meter and no power is coming into the back cluster for the break lights only all other lights are working fine, Can anyone help point me in the correct direction on how to fix
Many Thanks
Check all the fuses in the driver's foot well fuse box first.
I would suggest the brake light switch is the first place I would look after that.
^ this. Fuses are notorious for providing bad circuit. Brake light switch is on pedal bracket and nut can work loose.
