4pot and disc set up for w203
Atlas01copco
C320
Hi
I'm looking to upgrade the brakes on my sport edition
Must be in good condition
Cash waiting
OP
OP
A
Atlas01copco
C320
https://www.ebay.co.uk/itm/172754453991
Please for you guys in the know
This listing is for a set of "AMG" callipers
I've noticed that they have bee tossed over in wheel silver paint and new decals put on
The description is that they are in good condition
Do any of you know if these are what they say they are as I think they are way over priced for what I think are not AMG equipment.
OP
OP
A
Atlas01copco
C320
https://www.mbclub.co.uk/forums/general-discussion/43441-my-c200k-pics.html
See post 42 for my previous pics.
From memory, I payed £250 for the discs and callipers (?) That was a good price.
If it's any help - they are the same callipers as fitted to the C32 - and the SL350.
Thanks for that
you had a result with your setup
I'll just have to keep looking, I'll just have to be patient and I'm sure some will turn up at an acceptable price
OP
OP
A
Atlas01copco
C320
The one you spotted I've purchased and the other one was also listed
So 2 for £84
Can you tell me, the brake hoses are they the same?
Cheers
Cubase
Buxton
SL 350
So you are saying that they would fit the w203?
Even though they are off an sl350?
Yes they'll fit.
So 2 for £84
Cheers
I didn't spot the other one - well done. That's a bargain.
Get them sprayed or strip down and powder coated -
You can use your existing brake hoses.
Then all you need is the discs and pads. Something like this...
FOR MERCEDES C32 C320 C350 AMG FRONT 345mm DRILLED BRAKE DISCS BREMBO PAD PADS | eBay
OP
OP
A
Atlas01copco
C320
Yes they'll fit.
I will strip them down inspect for piston leakage , re bolt and paint
I'll post some pictures as I'm going along
May take some time as I'm very busy on holiday at the moment lol
Thanks for your help
OP
OP
A
Atlas01copco
C320
Gave the callipers a good clean up this evening and a coat of paint
I've noticed that these callipers are for the 330mm discs I think
On the carrier it's got 330 embossed on them so I'm guessing that they are for the 330mm discs ��
I will double check at the weekend as the discs on my car are 330s
I've ordered new discs and pads 345mm and they are on there way to me
OP
OP
A
Atlas01copco
C320
Got these in error so I've put them on eBay
182670452205 Is the item number
They are for 330mm not 345mm
astamir
london
w208 silver clk55
Where were these just yesterday?))) I managed to damage the bleeding valve on one of the calipers that I'm trying to put on my clk55 w208, and ordered one from a second hand parts sellers.
How much would you take cash on collection?
Cheers.
Cubase
Buxton
SL 350
Did they fit your car with your 330mm discs?
It looks like your analysis of the '330' written on the carrier was correct?
OP
OP
A
Atlas01copco
C320
Cheers.
Cash on collection £100
OP
OP
A
Atlas01copco
C320
To be honest I never offered them up because of what it had embossed on them
Didn't see much point really
astamir
london
w208 silver clk55
Hi
Just wanted a bit more info on the calipers.
You said it's for 330mm discs my discs are 334mm and the calipers I've got from w209 clk55 are for 345mm.
So I was thinking put those on and replace the discs for 345 but if these 330mm would fit my w208 clk55 with my just recently replaced 334mm discs I would like to put these on and leave my new discs on.
Also about the condition of the calipers have you refurbished them like replacing seals or pistons or were they in a good condition?
And finally can I have your contact details and address if I would like to collect them.
OP
OP
A
Atlas01copco
C320
Hi
the calipers are not refurbished
They are just in a good condition as for fitment I can't honestly answer you on that
All I know is they were off a c class w203 and they are a 330mm caliper
