Mcvites69
Hi guys I've spent a few hours looking in the threads and cannot find a solution. so here goes
I had a mechanic fit a set of lowering spring to my 500 sec , before it drove without fault no warning light at all.
When he was trying to remove one of the rear springs he caught the rear brake line and snapped it clean off, so he replaced the broken brake line, bleed the brakes as normal (didn't touch the ABS ASR module) the brake came back to a great pedal, but now the ABS ASR warning lights are on! When you start the car they go off as they should, but as soon as you drive off they come straight back on :fail
Any ideas guys ??????
