Is THIS what you are looking for
OK I just put my brain in gear and remembered it's a Lysholm charger on these cars and not an Eaton like mine
Is it, i thought they were all Eaton!!!
Had a brief look for Lysholm chargers and the only thing i came accross was these chargers are normally fitted to US only vehicles.
But either way, i think im going to have to either strip the engine bay apart to look for something smaller than a 5p coin, or weld the hole shut . . . . or even perhaps just put some good old Blue Tak in there.
But first, i think im gona go and cry for a little while in a dark corner.
Can you remember the rough length of the bolt. I am pretty sure it is 1/8 tapered thread but not sure on the length.
I'd be worried about where the original went and would suggest you find that first. If it's gone down in the vicinity of the pulleys that could cause all sorts of damage if it got caught up and could come out like a bullet.
If you do find it you haven't got the other problem to worry about anymore
I doubt you will find it the most likely place it will end up is under the supercharger
