Hi
Still trying to make up my mind what I want to do with the engine. So far performance wise I changed my 2013 c63 for :
- eurocharged v5 tune
- quaife lsd
- filters (set of k&n and green)
- larger tyres.
All round good power and grip, going to import the weistec trans cooler next and fit. Ignoring exhaust mods due to noise and daily car. However went for a run against a 2017 m4 and was not pulling, just about level. Got me thinking and could not see any videos online, how does an older stage 1 2012-2014 weistec build pull vs a newer 4ltr turbo c63 (stock / modified) perform 0-60+. Spend 10+ grand on charger or just save for newer model as performance will be far greater and tune using stock components and ecu tweak? Anyone done any runs? Would a stage1 weistec be useless in winter in comfort mode eg lower gears just causing too much wheel spin meaning I need a second car which I don't want? Mines fine in wet/cold at present.
- quaife lsd
- larger tyres.
