639 bodywork
t567wab
Croydon
S211 E55K, Vito 122 Sport X
I happily drive Vito 111cdi 2004.Just wondered what's the difference between,let's say my one,and 2007 model regards bodywork.My body's begin to rust :dk: Does it get better with younger models?
D
Deleted member 37751
Guest
They were all meant to be galvanised from some time around 2004, yet I still see the odd rusty one newer than that..
OP
OP
t567wab
t567wab
Croydon
All of them?I've heard they're galvanised after 2006.
BTB 500
MB Club Veteran
Shropshire
R129 SL500, W639 Vito 120, S205 C300
I'm not sure when they started galvanising the 639, I thought it was 2005 (based on build date of course ... not when it was registered). You can tell by the existence (or not) of the 12 year bodywork warranty.
But 2004 ones definitely weren't - a friend has a 54 plate that's in quite a bad way (nearly as bad as a contemporary E Class :D).
D
Guest
I'm led to believe that they started the galvanised process around the 54/05 plate.
But, yes, if you go for a 2007 the chances are it shouldn't rust. Go for a metallic painted van to better your odds.
OP
OP
t567wab
t567wab
Croydon
I'm going to keep mine for a while,just bought it last year.
But the next one will be 2007+ and met. just to play safe.
Thanks guys.
P.S.Bill,is that original MB flooring in your "beast" ? :)
I like it a lot.
BTB 500
MB Club Veteran
Shropshire
I like it a lot.
Thanks!
Yes, the grey flooring comes with the Dualiner 'comfort pack' (along with the full-length roof lining, side lining, rear speakers, rear courtesy lights, etc.). Plus M-B rubber mats front & back.
