hi there.
im new here found you in a search and thought i would try and fix a headache i have had for a while if possible.
i have a really strange problem with my passenger electric window that searching cant seem to fix (have to say at this point i don't get on to well with searching for some reason) anyhow, the window will go up and down when the ignition is first turned on / van started but as soon as the van starts charging (battery light goes out) it stops and that's it until you take the key out and in again.
any help on this would be really appreciated as im pulling my hair out, after taking the door cards off and finding a ecu in both of them i am kinda thinking the worst (how technical do you need to make a window!)
oh and its a 54plate 111cdi vito if that helps.
regards sid.
regards sid.
