axelvic
I have an 07 E280 CDI with 7g Tronic. It’s my first Mercedes with this transmission although I’ve had a large number of cars with 722.6, which I’ve always liked. Mind you, I’ve had to replace the circuit board a couple of times which is fairly easy and not too expensive. This one though hesitates before engaging 3rd (first gear change when driving in comfort mode), letting the revs go up to a bit over the 2.000 mark before engaging again. I’ve just had the transmission fluid and filter replaced by a workshop since I don’t have the pump needed to fill the transmission. The car has done 160.000 miles and according to the service records it’s had it fluid replaced when it should previously. Is there anyone who has had a similar problem?
Regards,
Axel
Regards,
Axel
