rmvembe
- Sep 13, 2014
- E55K
On my 61' ML350 CDI, I've noticed the car will hold onto 6th gear and after a few seconds say up to 30secs, It will finally change into 7th. Once the shift into 7th is done, the transmission will shift through all 7 gears smoothly and timely. When this happens you can't manually change gear into 7th. This delay into 7th occurred since getting the car 2 years ago and has not bothered me. It's not occasional and happens 3/10 times. I had the box serviced a few days ago and the oil was not bad. There is no jerkiness, hard shifts or any of the 'faulty' transmission-related signs. Has anyone else experienced this?
Thanks you all in advance for your responses and comments
