ACID
Hi
Guys
I am just gathering some interest if anyone would like to TCU remapping on the 7 Speed AMGs, both Converter and MCT based Transmissions are supported.Increased Line Pressure, Faster Shifting, More Precise Shifting.
Your valve body, it is modified using our proprietary techniques to increase line pressure and improve shifting characteristics. Next we make changes to the TCU electronics to compliment the physical modifications. Once complete, the valve body is bench tested.
The Valve Body Upgrade allows the transmission to apply the proper amount of line pressure to the clutch packs. This calculated increase prevents slipping of the clutches and allows the transmission to reliably handle higher torque output from the vehicle engine as well as expanding the lifespan of the transmission.
Prices will be given at a later stage and all this will be done at MSL within 1 day.
In the Next Few Weeks we will have a car ready for anyone wanting to test this out.
Acid
Guys
Acid
