I've yet to start the oil change on my 7g gearbox but have had past experience of a R129 gearbox torque converter that had no drain plug. Apparently some did or didn't in my case. My present car is a 2004 500SL fitted with a 7 speed box (7g) Am I possible going to find the same problem, no torque converter drain plug? If so is it a case of draining filling from the gearbox sump pan and repeating the process as the next best option to replace as much of the oil as possible? Thanks for any replies. J C.
