todorpavlov_
- Jun 1, 2011
- E 280 CDI
Hi
Help, I recently bought Mercedes E class 280 CDI, 2006, 160 000 km on the clock. I love the car, but I'm having problems with the 7G - tronic gearbox
Here is the problem
Changing gears up - Upshift
Sometimes the car has uncomfortable up-shifting (jerk, push) when the car changes from 1st to 2nd; 2nd to 3rd; and 3rd to 4th. This does not happen always but approximately in 50% of the gear changes. Changing gears forward from 4th to 5th; 5th to 6th; 6th to 7th is very smooth. The engine running temperature does not influence the gears change.
Changing gears down - Downshift
When changing gears from 2nd to1st (e.g the car is going to a complete stop), with the engine and the gear box not warn enough (e.g. morning cold start) it jerks, pushes a little bit stronger. After engine reaches the nominal working temperature of 90 C there isn’t any more uncomfortable downshifting 2nd to 1st gear changes, however the uncomfortable up-shifting (jerk, push) is there.
I have been trying to solve that for more than a month without any luck. A couple of times I went to Mercedes Benz Dealer and they did the following, but still no improvement:
Thanks you in advance for your support and cooperation.
Here is the problem
- Changed the gearbox oil and the filter.
- Updated the latest version of the software of the gear box.
- Erased the adaptations of the gearbox
- Cleared the gearbox adaptations and let the gearbox to build its own adaptation values;
- Tried to readapt gearbox by using Mercedes Star Diagnosis;
