Dutchbenz
- Aug 20, 2017
- 2008 S204 C230 estate
2008 S204 C230 with 7G tronic.
I have a question about the use of the comfort/sport mode.
Apart from the obvious functinality I was wondering if it should be wise to permanently use the sports-mode.
From the days I owned a P38 (previous disease I'm cured from) I remember I used the sport mode also when on hilly roads or towing a trailer. The engine then shifts at higher revs, less strain on the torque converter (heat building up) and coolant circulates faster. Even mpg improved a bit, depending on your right-foot's behaviour of course.
(Not that you should drive a Range Rover when mpg is a concern.)
Does all this go for C230 too?
In comfort mode the car pulls off in 2nd gear (torque converter), in my view only recommended on slippery roads and in general I like the more direct response in sports mode.
On a side note: the handbook says it should revert from sports- to comfort mode when stopping the engine, mine stays in sports mode the next time I start her up.
What are your ideas for this matter?
Thanks for your answers,
Tony.
Tony.
